About 10 months ago I lost fuel to the motor. Installed new Bosch replacement fuel pump, and had to also install a new fuse for the fuel pump. Noticed after I replaced the pump that the fuse was blown
Today I lost fuel pressure again - noticed right away the fuse was blown.
Inspected wiring and did not find any obvious shorts.
Installed a new fuel pump (not Bosch this time). Before mounting the tank back up, I turned the key w/o starting and verified that the fuse did not blow. It did not. So I finished putting the tank back into place.
The vehicle started, ran long enuf to back out of the garage, then quit. Fuel Pump fuse was blown.
So I either (miraculously) got a bad fuel pump, or I did not fix a short I previously missed (but then why did it run for a minute?), or there is something that is causing fuel pumps to short and it takes only a minute before the fuse blows.
Any clues what to check?
Does this sound right ? To check the voltage to the fuel pump I believe I need to drop the tank to unplug the connector on top of the fuel pump, then use a multi-meter to probe the supply voltage with 1 probe, and ground with the other.
Thanks in advance
Thanks in advance
