Normal. Some people are intentional about the position of the barrel of that joint because it can determine how far you can stuff before the pumpkin meets the bar. You can adjust it by setting the position you want when you tighten the jam nut on the other end. Yours is probably good because it'll probably go straight vertical and push the bar the farthest forward right when the Diff cover tries to slip behind it.
