Is this normal?
Jeepers
London, KY, United States
Not sure what to make of clicking when only one tire turns, you can they'll "catch" and both will spin if you turn it slowly, turning the axle makes them both turn with no clicking
Video of front differential
Sent from my SAMSUNG-SM-G935A using Tapatalk
Thank you guys for the quick responses. What is the easiest way to tell if you do have a locker installed besides popping off pumpkin cover
Shift into 4Hi and see if the steering gets noticeably wonky on the street after making a few turns. A front locker will make steering noticeably harder and it will buck during turns whenever you're in 4x4.
Note that the steering will not instantly go back to normal after shifting back into 2wd, it will take a few left/right turns to get the locker disengaged.
That is exactly what it is doing! Steering will feel very tight almost fighting with it In a sharp turn. I will shift back into 2wd and it takes a little bit for it to disengage, usually will a pop/bang
Like Jerry said sounds like you have a lunchbox locker in there
That's a relief, went to a shop to get a alignment, mechanic I hadn't met was trying to convince me I needed gears replaced and everything and he was surprised the axle hadn't fallen out, didn't sound right to me because my jeep drives great side from the tie rod ends that need replaced but that sound was new to me because I'd never jacked it up and turn the wheels to see what it sounded like because like I said, there was no indication of a problem.
