I have a very slow atf leak. Today I found this. What is this hose? Where is it supposed to be connected? I don’t see anywhere obvious it should be in this area.
So I got back under and I found the other end with the little cap on it. It has a bracket that it’s stuck to but has come unscrewed from wherever it lives. So this end i pictured looks like it should actually be attached somewhere. I guess it’s time i learn how to drop my transmission!From the pics it kind of looks like your t-case vent hose. One end goes on a nipple on top of t-case and other end is in a clip that goes in a top bellhousing bolt on driver side if I recall correctly. Seeing as how it takes atf it very well could be.
So I got back under and I found the other end with the little cap on it. It has a bracket that it’s stuck to but has come unscrewed from wherever it lives. So this end i pictured looks like it should actually be attached somewhere. I guess it’s time i learn how to drop my transmission!![]()
There should've been a hose clamp on that on the nipple on top of the transfer case. I'm pretty sure you can get to the vent w/o dropping the skid, although the hose clamp might be an adventure to secure. The plastic piece can be found on rock auto & amazon.
