That part doesn't look like the one on my 2006, so I figure it's earlier than that.
What Wrangler part?
What Wrangler part?
It's a Broke J.It was FB but I'm not even friends with, or a member of, or whatever options there are to that member, or group or whatever it is, I just got it.
Anyway, here it is:
Looks like a leaf spring mount as well..Looks like a Control Arm Mount View attachment 111078
YJ’s all had 231’s with slip yokes.It's a TJ judging by the slip yoke on the rear ds and the previously mentioned control arm bracket by DrD
Hahahaha WRONG! hahah try again.YJ’s all had 231’s with slip yokes.
Got the notification that you are now following me here, I see what you are doing.Hahahaha WRONG! hahah try again.
207.Got the notification that you are now following me here, I see what you are doing.
I'll bite, Which YJ came from the factory without a 231 and/or without a slip yoke?
oh cool, a 207, never knew about it. Was it in half of the first year builds?207.
I ain’t doing anything besides correcting your “fact”
Yes you are correct, they did have 231's, BUT, they all had slip yoke seals, the TJ has a tc output shaft seal and a "Dust boot" that clamps to the output shaft and the slip yoke (Just like what is pictured)...YJ’s all had 231’s with slip yokes.
No he's not totally wrong, all YJ's have slip yoke drive shafts but the YJ's tc output seal seals to the yoke, the TJ's seal is on the tc output shaft not the yoke. One year has the NP 207 ('87) but it was still slip yoke.Hahahaha WRONG! hahah try again.
I believe the spring eye bolt hole is in line with the body mount on a YJ, where this is clearly behind that. ICBWTLooks like a leaf spring mount as well..
X2I believe the spring eye bolt hole is in line with the body mount on a YJ, where this is clearly behind that. ICBWT
