Another upgrade is to use the 5.7 hemi valves on a 7120/0630 head, you can still use the bee hive springs and retainers but you get a larger intake and exhaust valve without any fancy work at the machine shop trying to find retainers, springs and keepers. Small block chevy valves are definately not a option, I spent $589 on pontiac springs, oldsmobile retainers and some wierd ford lock to run 1.94/1.6 valves.
You can also use a cam with a wide lobe separation angle. Fuel injection likes the wide LSA, it gives better response to the sensors. You also need to match the cam and fuel injectors. There is a calculator over on the jeep strokers website or even the microsquirt one that bases the number of cylinders and the HP will give you the correct injector rate based on system fuel pressure.
Tim
