Huckster
Do y’all think I am on the right track thinking my intermittent stop issue may be the crankcase position sensor??
I am almost 65 years old. Not extremely tech savvy. I like the Haynes and Chilton manuals. YouTube is great fun to watch. The Haynes manual had the ohm test for the crankcase position sensor. I recently had surgery and it’s hard to get under or in the engine bay…very irritating but I’m working on it
A bad crank position sensor usually results in a jeep that will sometimes die while driving or just not start at all. I’m not saying it couldn’t come back to life as you described, just that I’ve never seen/heard about it.
I guess I thought if the CKS was bad what actually happens was it would trigger the ASD to turn off (the ASD is actually what shuts off the car in this case), and I believe it takes the key being turned to START to re-engage the ASD. So that would mean that maybe the interrupt is short enough that the ASD doesn’t shut everything down before the CKS returns to good order? I’m just thinking out loud.
Next ride take a bottle of water and douse the CPS if she quits again. If it's going bad cooling it can get you going quickly.
Cool… but a bit scary dousing electrics with water. I guess it is waterproof ish
Non issue since the engine compartment is open to weather.
l cleaned up theNon issue since the engine compartment is open to weather.
