First off, hello! This is my first post so sorry if anything is incorrect. It’s incredible how many forum posts I’ve come across with the same issue...My Jeep will stall at idle randomly unless I’m holding the accelerator down. When I let off it either idles perfect for a bit then stalls or will stall as soon as I let off. Sometimes it will drop to 300-400 rpms and surge back up to normal idle on its own. It even idled all by itself for an hour yesterday when I was testing it after taking it for a drive. I bought this Jeep a couple weeks back and the guy said someone had left the acc on so the battery was dead. I’ve since then replaced the battery. All I’ve gotten from different posts is that it could be a mountain of things, I’m going to post videos just in case someone notices something before I start replacing and throwing money at everything that’s mentioned.
I’ve already removed the throttle body and cleaned it out including the IAC. The TPS seemed to have been replaced already. Also no CELs are being stored.
Here are the videos. Thank you!
