I have 98 tj that the battery died on so i jumped it drove it around for awhile and then let it sit on the charger all night. The next day went out to start it and had nothing so i then replaced the battery. After replacing the battery i still had nothing so i did a little digging and thought it was the ECM. Replaced that and got it to start cranking but still wouldnt run so i did a little more digging and replaced the crank shaft censor and the cam shaft censor. After that now the jeep will start but immediately die unless i turn the key off and the back on quickly and repeatedly. it had the black key so that shouldnt be the issue im all out of ideas.
