I don't because I replaced my blown OEM sub with an older Kicker model and just run it off the OEM amp. I'm going to be upgrading the audio later on so I haven't done the research yet.any recommendations for amps for it?
Kicker used to make a small mono sub amp, model PX200.1. Works great & doesn't take up much space. Mine is bolted to the passenger side kick panel.any recommendations for amps for it?
I ended up going this route:
https://www.crutchfield.com/S-yN0COMhAeOE/p_777B8PTD/Sound-Ordnance-B-8PTD.html
I saw it in another forum and it’s a really snug fit, but sounds great and a massive upgrade from the stock one. I also like how it’s all contained in the console, so no large amp out in the open begging to be stolen.
Good info on that thread, even looks like somebody is selling the amp mentioned.Have you read Chris' write up in the sticky section of this website? He spells everything out step by step. The Kicker PXA200.1 amp and 6.5 amp work perfectly for the center sub install. And the pricing is hard to beat. The sound is great, well, as great as it can be inside a TJ going 60 down the road. You can spend more, but you won't get to hear any better sound.
Any chance you have pictures of this amp/sub mounted in the center console? I was thinking of adding the Sound Ordnance as well. Thanks!
Did you have to modify anything inside the console and didn’t you use the harness off the old sub to connect amp to the speaker harness?I ended up going this route:
I think i'm going to go with the Kicker CompRT 6.75" 1-Ohm Subwoofer with the Skar Audio RP-350.1D Monoblock Class D MOSFET Amplifier with Remote Subwoofer Level Control, 350W
https://www.amazon.com/gp/product/B01BLVEZG6/?tag=wranglerorg-20
