Driving to work bright and early yesterday morning. I'm about 15mi from home going about 70mph down the highway when my engine sputtered a bit. I let off the gas and got over a couple of lanes instinctively. Soon as I gave it the throttle it sputtered and backfired so I immediately got off the freeway and onto a side street and shut it down. No engine light, no strange gauges, all pressures and temps normal. Looked underneath and nothing. Opened hood, only thing I did was depress the schrader valve on the fuel rail and fuel sprayed out. Have 1/2 tank of fuel.
Let it sit for a min or two and tried to start. Turned over just fine but didn't want to start. Let it cool a bit more for about 30 min and started right up. As soon as I pressed the gas pedal it sputtered and died again and had trouble starting again after that. Called a tow and got it towed home.
Jumped in my pickup and went to work. Came home and Jeep started right up. Hooked a code reader to it and nothing. Let it idle for about 5 min, hit the gas a few times and no problems.
This morning I hooked a fuel pressure gauge to it and sat at 46 psi at idle. Shut it off and sat at 45 psi for more than 15 min afterwards. Disconnected pressure gauge, started it up and let it idle up to operating temp, runs fine. Dumped in a bottle of the Techron fuel additive just because I had one in the garage.
Basically I still don't know what caused this. I kept thinking fuel pump but I changed mine out about 5 years ago and fuel pressure gauge sorta ruled that out. Maybe water in the fuel or bad gas? But since last fill up, nothing happened before that, not even a hiccup of any kind. We did have quite a bit of rain past week and I washed it really good night before (hence the shiny pic).
Thoughts on anything else I can check or troubleshoot? i'm afraid of leaving my driveway to be honest without knowing what the stall was from.
