Jeu latéral arbre Dana35C
Translation: "What is the maximum lateral play of the half shafts of Dana 35C?"
*I see from his other posts that they are being translated to English. That's cool. You doing that, @Chris?
The max end play of a c-clip shaft would be the distance from the end of the shaft to the cross pin in one direction and the distance from there back to where the c-clip is fully seated in the counterbore in the side gear. I'd say likely no more than .060 total.
You do this in your sleep, don't you? ;)
Reactions: XISophos and StG58
[QUOTE = "mrblaine, post: 278357, membre: 164"] Le jeu maximal d’un arbre c-clip serait la distance entre l’extrémité de l’arbre et la goupille transversale dans un sens, ainsi que la distance qui les sépare où le c-clip est complètement inséré dans la fraisure du pignon latéral. Je dirais probablement pas plus que 0,060 au total. [/ QUOTE]
Merci de Votre réponse
Y a t'il un manuel qui expliquerait ceci ?
