I apologize in advance if this has already been addressed. I am going to be swapping the axles on my TJ to JK axles. I know of all the truss mounts that I'll purchase and I'll have to run JK steering or a 1 ton setup. But what I can't find is what pitman arm I need. I currently have a 5.5 RE long arm kit installed with a 2in drop pitman with the Y-link steering. So do I need a TJ pitman or JK pitman. Everything I read says the TJ pitman will not throw the tires all the way and the steering box stops will contact first. But I don't know if the JK arm will fit on the steering box shaft. I know people have done this swap and any help would be appreciated.
