Has anyone put an oem Jeep jk radio in a tj I have an 06 rubicon and would like to put the 7” OEM radio from a jk in my Jeep has anyone done this and if so how difficult was it?
It would be quite difficult as the dash bezel on your TJ is meant for a standard DIN radio. There are aftermarket double DIN bezels, but those aren't big enough for a 7" radio. That along with an aftermarket double DIN radio is your best bet if you want a larger screen.Has anyone put an oem Jeep jk radio in a tj I have an 06 rubicon and would like to put the 7” OEM radio from a jk in my Jeep has anyone done this and if so how difficult was it?
Let me know if you succeeded in doing this. I'm currently trying to figure out what to do about the wire bundles since the male TJ plugs dont fit the female sockets on the JK head unit unless I'm doing something wrongHas anyone put an oem Jeep jk radio in a tj I have an 06 rubicon and would like to put the 7” OEM radio from a jk in my Jeep has anyone done this and if so how difficult was it?
The standard TJ dash uses a weird Chrysler size that is about 1.5 DIN. It's not standard DIN.It would be quite difficult as the dash bezel on your TJ is meant for a standard DIN radio. There are aftermarket double DIN bezels, but those aren't big enough for a 7" radio. That along with an aftermarket double DIN radio is your best bet if you want a larger screen.
Sounds like im buying an aftermarket. But what is good for a lower budget for the time being?The problem is much more than just the wiring harness connectors not fitting and more wiring existing with the JK radio harness.
The JK radio has the VIN anti theft protection programmed into the radio and requires CANBUS (ECU communication) to operate properly.
You may be able to hot wire the radio for powering up, but the radio requires the VIN be reset along with the newer JK radios having a multi digit code (anti theft feature) that is required.
You will need to decide whether adapting the harnesses and getting around the anti theft features are really worth the trouble instead of just purchasing an aftermarket radio to
Shop Crutchfield, they will get you going and include any wiring harness you need. If you get a double DIN you will also need the new bezel that you can buy from them. I just checked and they are out of stock of many stereos. They show NO stock on double DIN from major brands like Sony, Kenwood, Pioneer, etc.Sounds like im buying an aftermarket. But what is good for a lower budget for the time being?
Chip shortages have been crazy. I installed a Double DIN Sony 5500 in April and then a month later tried to get the same for the XJ and stock was wiped out. I hope Crutchfield survives these shortages.Shop Crutchfield, they will get you going and include any wiring harness you need. If you get a double DIN you will also need the new bezel that you can buy from them. I just checked and they are out of stock of many stereos. They show NO stock on double DIN from major brands like Sony, Kenwood, Pioneer, etc.
