JKS Quick Disconnect sizing.
Chxse
Ontario
Hey guys. Recently purchased the 0-2” JKS quick disconnects for my TJ. It’s currently sitting on a 2” BDS lift. I’m wondering if these will be too small? Or should I use them fully extended? The BDS springs are a bit taller than 2”. TIA.
You will need to adjust their length to provide the proper sway bar end angles.
My '01 has a 2" spring lift and the 0-2" JKS disconnects are just fine.
The 0-2" JKS disconnects will actually work with slightly more than a 2" lift, but then the threaded rods are at full adjustment....
Okay thank you. I’m not too worried about them being close to full adjustment as long as they function properly. I don’t plan on doing a bigger lift for a long time as I have a 1.25” body lift aswell.
