My muffler has been making a racket so I finally found where its weld had come loose from where it holds the rear pipe into the muffler. Ok, drag out the welder, clean things up with a wire brush first.
First of all, my helmet wouldn't stay on my head. Laying on my back under the Jeep, every time I would lay my head back, that would push the headband adjustment knob in and release the head band so the helmet would fall off my head. Multiple times.
So then the wire would stop feeding for some reason, it never had that problem before. Tighten up the wire feed friction roller a tad and it was still not feeding 100% of the time. And this is with a Miller MIG welder, it's a good quality welder. Ok, keep at it anyway.
Then I'm welding and it looks like I'm blowing boogers onto the joint instead of welding. Sputtering, splattering, WTF. Thinking it's not getting enough shielding gas, I move the nozzle out a tad to trap more gas around the joint. Keep at it, figure I didn't get the joint cleaned well enough so I went at it again with the wire brush. No help, still looks like I'm piling boogers up over the joint. But they're holding so I say WTF and just keep at it just so it's better than it was. Well it's holding, kinda sorta at least, but heaven help me if @mrblaine sees it as is lol.
So I crawl out from underneath and start winding up the wires, gathering the tools, and rolling the welder back into the garage. I spot the gas valve on the back of the welding cart and instantly figured it out... sure enough, I forgot to turn the frigging gas valve on. F***. I'll redo the welds when I get back under to replace the track bar bracket. I apparently need a welding check list dammit.
1) Turn the effing gas on.
2) Turn on welder.
3) Weld.
2) Turn on welder.
3) Weld.
