So my jeep stranded me for two hours after deer hunting this morning. I put my key in the ignition and it would not turn. After two hours of praying, removing the shroud, and trying to remove the lock cylinder (to no avail), the key finally turned and allowed me to crank it and return home. Once I parked it and turned it to the off position it will not turn again. I looked it up in the service manual (didn’t have a copy on my phone) and it says the key must be in the run position to allow it to be removed. The local NAPA dealer has a key cylinder in stock but it needs the tumblers added by someone else other than NAPA. Any suggestions? I need to get the old key out first but I saw from searching old threads here that it could be started with a screwdriver after the cylinder was removed. Any recommendations would be appreciated, specifically how to get the cylinder out if the key won’t turn it. It is a manual transmission and the key doesn’t have a chip.
Sent from my iPad using Tapatalk
