After installing the Currie Currectlync Friday I setup an alignment with Firestone for Saturday (I have a lifetime policy) to check and fine tune if need be.
On the way home I was hearing a rattle in the front of the Jeep so I decided I would look at the front end this morning when it was light out side.
This morning while under the Jeep greasing the tierod ends; I found the clamps for the tierod ends at the center point of the drag link and at the drivers steering knuckle could be spun around freely with two fingers.
This is an accident waiting to happen; luckily the threaded section of the tierod end did not come loose from the tierod assembly while I was driving home.
I tightened the clamp bolts and then rechecked all of the other bolts that the alignment technician could have touched.
This morning after Firestone opened I called and talked to the same guy I checked out with yesterday; I explained what I found, what could have occurred IF I had not found this problem and that the alignment technician NEEDS to be talked to about their attention to detail.
While he said that he would have a serious talk with the alignment technician; I am not real confident this will resolve their problem of attention to detail.
