I changed the brackets for the front axle lower control arms for my 06 rubicon (barnes) but Im not sure if this is how it should look like... (no cam bolts) After the alignment at the shop was done.. the jeep was still leaning a bit to the driver's side... Not sure if the not-adjustable arms that I have is messing with that... Those arms are for a 2.5 inch lift and I have 4.5... Im planning on changing the arms for some core 4x4 ones but right now Im saving for the regearing..... Not sure if that's how they should look like.. Not sure if the arms are messing with the leaning problem... Not sure if the gears should be kept as priority 1 or if I should get some adjustable LCAs and push the regearing a few months more... Ooooor maybe just some cam bolts would be enough....
