Hi all, I've noticed in the past couple of months that I have some sort of leak that leaks to a small pool of water basically right in the middle of my floor liner on my drivers side (RHD Jeep). After some research I had originally thought it was because the cowl was clogged up but I had a look and it's definitely not that. In the picture I've attached, the water drains fine through the bit i've labelled 2, and 3 (the cabin intake) empties onto the passenger side (this was what I originally thought it was). Where I've labelled 1 has no leaks or anything so I've ruled that out too. I was pouring water from a bucket everywhere here and it ended up everywhere but the drivers side floor. So I'm not sure where to go from here. I've considered maybe one of the roof or floor seals but they seam fine when I go through car washes and such and also the water pools right in the middle of the floor under the dash so it doesn't seam like its coming from the door or roof. Any helps appreciated, thanks.
