Need help. 04 TJ X 6 cyl auto. Help me find a replacement box and/or where can I send it to be rebuilt?
http://m.oreillyauto.com/h5/r/oap/s...er&vi=5015472&keyword=Steering+box&reset=trueCan you give a link cant find it.
That model for a 2002 will not fit his 2004, one of the mounting bolt locations changed in 2003.
Good catch I wasn't paying attention at that.That model for a 2002 will not fit his 2004, one of the mounting bolt locations changed in 2003.
He needs one for a 2003 or newer to fit his 2004... this would be the one from O'Reilly's. http://m.oreillyauto.com/h5/r/oap/s...ck=Search_02840_1425923_-1&pt=02840&ppt=C0203
I might be wrong, but I thought the Durango box only worked on the 03 and older. I hope I'm wrong, as our pick and pull has a few Durango's, and I'd grab one for my 05.I thought that I've read a Durango steering box is considered an upgrade?
It's actually only the 2002 and older where the Durango steering boxes bolt right in. 2003 and newer models switched to the Mercedes steering system which has a slightly different mounting bolt pattern.I might be wrong, but I thought the Durango box only worked on the 03 and older.
I'm not a big fan of most rebuilt boxes so I avoid them. I've tried three rebuilt boxes from the chain stores and they all had play or failed prematurely. I'm 2 for 2 on durango boxes though and I got both on ebay.
I see Redhead steering was mentioned. I read about this company before but I'm confused on which box is for the TJ. They list 1972-2000 but aren't specific.
Call them. Can't remember the model number, but they don't list on website. They have plenty in stock though.
Thanks for the advice on the Lucas! I added it last week and the leak has slowly vanished. You just saved me ~$150.The Saginaw steering box used on 2002 and older TJs uses power steering fluid which the Lucas is best with. You can use the entire bottle of Lucas as the directions indicate.
I'm not really comfortable making a steering box recommendation other than to make sure to avoid anything from Cardone. The maker of the aftermarket power steering box I installed years ago on my previous TJ is retired so I can't recommend him.
If you're just looking to get on the road again I'd probably pick out one of the mainstream brands on Rockauto or at NAPA and avoid the low end stores like Autozone. I hear/read plusses and minuses on the Durango so no opinions there.
Mrblaine aka Black Magic Brakes is the steering guru here. He would really know the answers and have far better recommendations and advice. Good luck with it.
