What are some suggestions for good LED bulbs that will fit into the original fog lamp housing? I like the way the original fog lamp housings look, but they suck lighting ANYTHING up. Any suggestions??
No biggie, thanks for checkingYou could try Electrical Connections in Knoxville, TN. They have a lot of different applications of LED on their site and I’d bet you can find a suitable item to corrupt.
Edit: nope, I’m wrong. Seems they’ve shifted their focus to motorcycle only accessories.
+1000 on this! A friend of mine decided to put LED lamps in replacement of the halogens in his Pontiac G6. One headlight was illuminating the trees and the other was blinding oncoming traffic. He is obviously clueless, or just does not care.My recommendation would be to look for a LED fog lamp assembly. The issue with LED bulb retrofits is that with LEDs, the light is distributed differently than the halogen bulbs. The optics of the OE fog lamps assume that there will be a point light source in an exact location, something an LED bulb cannot quite mimic.
You will have better performance from an assembly because the reflector and lens are designed for the led bulbs. Not only that, it is less likely to have bright spots that blind oncoming traffic.
Improperly retrofitted LEDs can result in collisions due to the improper optics potentially blinding oncoming traffic. They can also result in a fix-it ticket.
There are fog lamp assemblies out there that use LEDs but look stock-ish.
