Hi there,
Newbie to Jeep modifications on a 2001 TJ. I’m having trouble with my LED upgrades to rear tail lights and front turn signals. I upgraded these to LED lights. However I did not do the side turn signals but I probably should.
First problem is the front turn signals only work when I have at least the running lights or headlights on which I don’t like.
Second problem is the turbo flashing on the turn signals. I purchased the LED relay and doesn’t seem to be working properly. One signal either left or right will work at normal speed but the other side will cause both the rear lights to flash.
Do you think it’s because I still have the old stock side front signals when everything else is LED?
Thanks!
Thanks!
