Led tail lights brake lights and blinkers
pvowelsii1967
Morganfield,ky
Is there an led replacement bulb that works on the tailights brake lights and blinkers. I believe the part number for the tail light bulb is 2057 but when I replaced it with the led equivalent the blinkers didn't work with parking lights are on.
Are your rear lights the same as UK spec i.e. orange blinkers?
I tried LED bulbs in tail/brake lights but they made horrible things happen to the other lights, but LED has worked well in high level brake, and reversing lights. I’ve not tried in blinkers as a new relay would be needed.
