I've looked over some older threads, but didn't see anything quite like what I'm having issues with.
I installed some new tube-style fenders that came with LED turn signals built in. I installed a new LED compatible flasher relay and now they only work if my headlights and running lights are off. I don't get the hyper flash, so I assumed the relay worked. I have the LEDs wired up to the side marker wires, as I'm going to install some JK turn signals in the grill CJ style. I did, however, wire the LEDs up to the front turn signal wiring today to test, and the issue was the same.
I'm using the LM470 relay from AutoZone, it says LED compatible and up to 6 lamps. Rear lights are stock.
