C.J. Roberts
Cibie Z-beam type headlights with Hella 100/ 80 watt bulbs,
Hella 550 fog lights turned out about 15 degrees to work as extra wide low beams, or cornering lights, set at the same height as low beams,
Four 55 watt driving lights. Good compromise between flood and spot. The outer set are aimed little above high beams, the inner set just above that. One switch operates the outer set, the next switch operates both.
All of them can be switched on either independently or with high beams.
I tried LEDs, but they made everything look like the contrast was up too high, kind of washed out. With halogens I can see.
