Lift and Tire help
Fallin22
I have a 98 Sahara that is all stock. I am wanting to put a 2 or 3 inch body lift on it for looks not necessarily off roading. I want to keep the driving and handling as close to stock as possible. What size tires would I need to get to make it look better once it is lifted? Thanks for any help
Reactions: Jheapr and Chris
With 2-3" of lift it will look great with either 32" or 33" tires. I had 2.5" of lift and 33" tires and it looked fantastic! Anything bigger wouldn't have fit (or looked) right.
Reactions: Jheapr
Did you need to replace anything else other than the coils and shocks?
Just put in a 2 inch lift, haven't driven it yet.
At 2.5 inches, no.
However, I have a Rubicon, which means that it already has a fixed yoke on the transfer case.
You'll most likely either need a transfer case drop (if you want to do it the cheap way), or a slip yoke eliminator (SYE) and new CV driveshaft (if you want to do it the right way).
Reactions: theflyingdrew
At 2.5 inches, no.
Okay, I just got a new driveshaft, yoke, upper and lower control (oem style) because a buddy of mine hit a center divider and it pushed the axle back. The oem sway bar links should be good right?
Yes, they will be good. If you're planing on doing any serious off-roading / flexing, you'll want either sway bar disconnects or a Currie Antirock (the latter is the best solution).
