I've been searching around and I feel like my doubts will be answered here:
ISSUE:
I am looking into adding 4 Hella 500FF series lamps (12V/55W ea) to my 2004 TJ (to be installed to the Light Bar that I just purchased). Each set of light comes with its wiring harness, relay and switch. I already have a Roof Light Switch installed in the center console switch pannel, the switch is rated 12V.
QUESTIONS:
- Is it possible (without burning anything) to install both sets of light (4 lamps total) using 2 relays but to that one switch? (My pet peeve is I don't want to many switches around, plus to keep it as "stock looking" as possible)
- if yes, what do I need? Recommended cabling gage, fuse amperage rating (at the harness/relay)
- Also, thinking of "fuse tapping" from the glove box fuse box (Why? In order to make my life easier and to tap into an "always hot" connection...so that I can turn light light on without having to start my Jeep) - Is it recommended? If not...any suggestion as to where to tap the load from to the switch?
Thanks!
Lights:
HELLA 005750941 500FF Series Driving Lamp Kit,6",clear
https://www.amazon.com/dp/B001TWD5GY/?tag=wranglerorg-20
Switch:
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=331689366092
ISSUE:
QUESTIONS:
Thanks!
Lights:
Switch:
