Thanks for the help. My cluster fuse was good and battery was good. I clean as many of the main grounds as I could fine. I pull my cluster and found one the two muti-connections apart. Reconnected and that was my fix. Cluster lights work and crazy gauges function properly and dome lights work.
Now on to figuring out why my engine light and ABS lights don't come on when you turn the switch to the on position. If anyone has any ideas let me know.
