Locking Hood Latches?
B1Toad
TJ Expert
Arizona
Anyone know of locking hood latches that you don't have to lock all the time? They would work as a normal hood latch and you'd only lock them when you needed to park somewhere you didn't feel comfortable leaving them unlocked. I can't use the center latch ones because I have the grill inserts.
Reactions: PNW_LJ and Zorba
Reactions: B1Toad and Akitadog
Side latches or front? I have grill inserts as well and though I would like to remove them, they have been on for a while (installed by PO) and the paint is scratched underneath.
I use a Drake side latch knockoff that can be locked or not..
Reactions: B1Toad
I'm going to try this one, even though I have grill inserts I think I can cut a hole in the grill insert for the lock cylinder. Does anyone know if this one can be left unlocked for normal hood opening when desired? I only want it lockable for certain times. https://www.amazon.com/dp/B009W8BJRO/?tag=wranglerorg-20
Let us know how it works - I have grille inserts, like them, but also want a lock.
