There seems to be some room for uncertainty in the wording Novak uses in this guide:
https://www.novak-adapt.com/knowledge/np-nvg-input-gears/
Which is interesting because I definitely have an AX15 and a long input gear.
In spite of this seeming problem:
Anybody else seen this before? Did some AX15s have splines machined farther into the shaft to prevent this interference? There don't appear to be any markings on the splines of either shaft to suggest they are making hard contact and the mounting surfaces make contact without any hint of interference. That said, by tape measure the end of the splines must be close enough to each other that they only clear because of the chamfer in the inside of the input gear shaft.
