I currently have LT285/75R16 M/Ts on stock 16" Moabs. I really want to switch to an A/T but finding them in a 16" with load range 'C' is almost impossible. I do like the Falken Wildpeak A/T3W. I have a couple of concerns with them. Should I be?
16" wheels are the work of the devil and significantly reduce the selection of desirable tires. Have you thought about biting the bullet and going to a 15" wheel where there's a huge variety of Load Range C tires?I currently have LT285/75R16 M/Ts on stock 16" Moabs. I really want to switch to an A/T but finding them in a 16" with load range 'C' is almost impossible. I do like the Falken Wildpeak A/T3W. I have a couple of concerns with them. Should I be?
Iirc the Cooper AT3 LT comes in range C. My 265/75R16 had a choice of range C or E.
... To @CodaMan: The tires you highlighted are SL (standard load) tires. You want LT tires (light truck) - with a C load rating if possible although an E load rating won't be the end of the world as some seem to suggest.
I currently have 3 issues with my current tires: 1) they are M/Ts and I'd rather have an A/T, 2) they are 16" and 3) they are load range 'E'. Now, I could live with all 3, but why if I don't need to.
With our light Jeeps, is a SL load a problem? They actually have a Max Load higher than the 33X12.50R15 and all the 15" LT tires. The big difference is 4 ply vs 6 ply.
Load ratings no longer equate to the number of tire plys. In the old bias ply days the load rating did equate actual number of plys, but when radial tires became popular the system was supplanted by 4 ply, 6 ply, 8 ply rated radial tires which did not directly correspond to the number of plys, and now by the alpha load ratings which have absolutely nothing to do with the number of plys.
LT tires are typically a stronger tire than a SL passenger car tire. Not only will the sidewalls hold up to more abuse, so will the tire treads. I tried to get away with SL tires in my younger days when I had no money and would resort to any number of rationalizations as to why they were "just as good" as LT tires. But they weren't.
If your jeep never sees dirt then a SL tire might be just fine. Only you can decide.
