I just posted this (below) in a very similar thread this afternoon asking about the 05-06 models, so I'm going to post it here as well:
The OPDA thing is overblown. Yes, you will find some who will say it's not and warn you to stay away from 05 models as if they are the plague. However, I've owned two 2005 models, and I have friends who own 2005 models as well. None of them including myself have ever had any OPDA issues, ever.
So you can take that for what it's worth. Again, I think it's been blown drastically out of proportion. Anything mechanical fails over time. It just so happens that some of them had issues while others didn't. The ones that had issues failed prematurely.
A bad OPDA is obvious. It will start squealing and the sound will be loud and unmistakable. The other way you can check for a OPDA that might be about to go bad is to remove the OPDA (a very easy procedure), which you can read more about in this thread:
What is the OPDA and do I need to change mine?
As for PCM issues, those are more uncommon than OPDA issues. That literally wouldn't even be on my list of worries.
Your number one worry should be rust, period.
Since I fully expect this thread to now devolve into an OPDA cage match, I'm going to bow out of this thread. You can listen to all the opinions you want. However, I'm going to leave my opinion (as I did before), and that is that the OPDA issue had been drastically blown out of proportion, as with almost everything else on the internet.
