Let's see your alignment spec sheet they should have given you. the only thing they can really adjust is your toe setting. Why did they adjust your track bar? You installed it, centered your axle, done. They should not have needed to touch it. Your drag link, on the other hand is used to center your steering wheel after they adjusted your toe setting.
