I just completed a 2.5 OME lift on my 04 TJ and got 31 inch tires mounted and had an alignment done. The Jeep drives straight but the steering wheel doesn’t return to center. I’ve read this could be a camber issue but I don’t have adjustable lower control arms (didn’t think I needed them with a 2.5 lift). Would installing cam bolts fix my issue and are any modifications needed for the install? What else could be causing the problem? I’ve checked the other steering components and nothing seems to be worn or loose.
