I bought a jeep with low oil pressure. I changed the sender, hooked a mechanical gauge to it and it was reading low. I shut it off at 10psi at 750rpm idle after 15-20 minutes idling. I then dropped the pan and found one of the bolts for the oil pump had fallen out. I also found the connecting rod bearings were worn…probably from low oil pressure. I changed mains and con rod bearings and put in a new pump. Ran it for 20 minutes and changed the oil. Very little metal compared to what I was expecting. Put in heavier weight oil. I let it idle again with the mechanical gauge and the oil pressure dropped to 8 psi before I shut it off. I took it for a spin and the pressure did come up 10 or more psi per 1000rpm. Any suggestions?
