Jeep TJ Rubicon, 2003, manual Trans.
When the key is in "Run" or "Start" position all of my ignition voltage is at 7.8V . Symptoms: Dash cluster instruments are 'dead', on signal LED are working, accessories like lockers, not working, ...
Battery is loaded with 12.8V, same voltage at power distribution fuse box.
Measuring all fuses that are working with IGN power have 7.8V on both sides of the pins, which is unusual as well. So something is really wrong there.
Didn't take the steering wheel column apart yet in order to check key switch.
So from your experience what is the most likely location of troubleshooting.
Bad fuse box, bad relay, or key switch??
Anybody has a wiring diagram what wires are connected from key switch in "Run" position.
Thanks.
Thanks.
