Horn will not work when the key is in the "On" position. Running or not running does not make a difference.
Works fine in all other key positions.
Fuse looks good.
Switched relay with fuel pump relay. No Change.
Cleaned the ground right near the horns under the hood. No change.
Swapped horn switch from a buddies tj real quick. No change.
Could it be the clock spring??
Just seems odd for it to not work only when the key is in the on position....
Fuse looks good.
