Anyone had an issue with lower radiator hose fitting? Here is the deal. I have a 1999 wrangler 4.0. I just replaced the water pump with a factory pump. New thermostat etc. I do have a Griffin aluminum radiator but have had it for years I’ve never had a hose issue though. Went to put new hoses on and the upper went on perfect. But the lower one listed at three different parts stores is about 4-5” longer than my old hose. Roughly the same shape though. The old one was cut off so not reusable and no numbers found on it. If I cut the new one to the correct length it looses the last bend and would partially kink. The only other hose option I see is for a right hand drive model. I ordered it but it won’t be here till Monday. I thought they just gave me the wrong part but I went to two different stores and they pulled same shaped hoses. Seems orielly’s, advance and Napa show the same hose from 1997-2006. Was there any different versions and if so do you have a part number by chance.
