So moving onto my next opportunity.
1st is difficult to get into, not impossible just not as easy at 3rd or 5th.
From looking around it appears that I have a spacer on top of the transmission and from what I think is some type of shifter extender. Body lift is 2.5” (hopefully soon to eliminate or lower to 1” or 1.25”). The resistance to shifting into 1st I believe is the bezel that holds the dust boot down. I’ve dremmeled as much as I can to give more clearance but still running just enough to catch at times.
It looks like if I rotate everything to the right about 90 degrees to the 3 o’clock position I might have easier shifting into 1st.
Has anyone ran into before? Or is there any reason not to give it a shot?
Picture is from passenger side so 3 o’clock would be straight down.
