Manual Transmission Issues
DarinN
California
Hi. I have an ‘01 Wrangler TJ that has 140 K mi. on it. Its been great for many years until recently it won’t go into first or second. 3rd- Reverse still work normally. I checked the fluid which was only about 20% below full . Since the fluid had never been changed I drained it and added Penzoil Syncromesh Manual Transmission fluid to the filling hole. I test drove and still no improvement. Any ideas? Thanks in advance!
Some people have reported better success with different fluids. Other popular ones are Redline MTL and Royal Purple. I say give one of those a shot. After a while though, things just begin to wear out. My 02 starting having finicky 1st and 2nd shifting around 140-something thousand miles too.
Well that sounds pretty bad but just changed to Redline MTL & my '02 feels like a brand new transmission. 2nd & 3rd were kinda touchy but yours sounds worse. Pennzoil Synchromesh is garbage...
Reactions: Jerry Bransford
If you put it in first or second before starting the engine, do either gears work still? If so, synchro issue, if no, she’s fubar.
Thank you! I really appreciate your input and advice!
Thank you! Very much appreciated!
The Redline MTL is the way to go. Just don't expect immediate results. It takes a few hundred miles to really notice the difference. It has to get into all the little places, chase out the old stuff, and coat everything.
I had the "won't go into second" problem a few years back. I changed to Redline MTL, and after a couple weeks driving, it was like a new transmission.
