JLLJ TJ Enthusiast Joined Oct 17, 2018 Messages 122 Location Whidbey Island, WA, USA Sep 17, 2022 #1 Silly question but, I’m swapping out the radiator and got an auto radiator from rock auto. Do I need to plug the trans coolant lines, or just install and go. Reactions: Jerry Bransford
Jerry Bransford Too many arguments and personal attacks, I'm done. Supporting Member Joined Nov 9, 2015 Messages 29,739 Location Fleming Island FL Sep 17, 2022 #2 Install and go. The transmission cooler section is completely separate and sealed off from the radiator. Reactions: RINC and JLLJ
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 71,101 Location Gillette, WY Sep 17, 2022 #3 Install and go, no need to plug the ports. Reactions: Jerry Bransford and JLLJ
OP JLLJ TJ Enthusiast Joined Oct 17, 2018 Messages 122 Location Whidbey Island, WA, USA Sep 17, 2022 #4 Thanks, I thought I could but with the way my luck has been I would do that and then have a mess. Not the worst problem I guess. Reactions: Jerry Bransford
RINC E pluribus unum = Out of many, one Supporting Member Joined Mar 15, 2020 Messages 7,951 Location A Sunny Place For Shady People. Laveen, AZ Sep 17, 2022 #5 JLLJ said: Thanks, I thought I could but with the way my luck has been I would do that and then have a mess. Not the worst problem I guess. Click to expand... Recently did mine with an auto radiator. All is well in the Arizona heat. Reactions: JLLJ
freedom_in_4low I'm a rooster illusion Supporting Member Ride of the Month Winner Joined Sep 26, 2019 Messages 8,534 Location Arcadia, OK Sep 17, 2022 #6 I would plug them just in case one day I discovered something I wanted to use it for, so it would be clean and good to go. Reactions: BlueC, JLLJ, ColoJeep and 1 other person
macleanflood I break sh!t Supporting Member Joined Jul 24, 2021 Messages 3,989 Location Fall Creek, OR Sep 17, 2022 #7 Betcha you could use it as a power steering cooler. Anyone explore that possibility? Inlet and outlet and hoses would be a PIA. -Mac Reactions: freedom_in_4low and BlueC
freedom_in_4low I'm a rooster illusion Supporting Member Ride of the Month Winner Joined Sep 26, 2019 Messages 8,534 Location Arcadia, OK Sep 18, 2022 #8 macleanflood said: Betcha you could use it as a power steering cooler. Anyone explore that possibility? Inlet and outlet and hoses would be a PIA. -Mac Click to expand... That was my thought as well but I didn't know if cooling the ps fluid with engine coolant would put it in the right temperature range.
