First, I would like to give a big thank you to all the posters on this forum. I have been lurking here for the last three months every since acquiring my 2004 sport. I have been able to solve many problems and improve the drivability just by doing a simple search and learning what others have done.
Now my problem.
I have been chasing a drivability issue and determined I likely have glogged catalytic converters. My secondary O2 sensor voltages bounce all over and my cat inlet temps are too high. But, before I replace my cats I am trying to determine why they clogged.
I believe the issue is with my MAP sensor. When connecting a vacuum gauge to the MAP sensor and using a OBD scanner, the vacuum gauge will show 17 inHg and the Scanner live data will show 12inHg at idle. When I increase the RPM to 2000 the vacuum gauge will read roughly 20 inches while the scanner reading increases to 9 inches.
Seems like the voltage supply and sensor wires might be reversed, but I checked it against the wiring diagram and all seems ok. I can't say for sure but it looks like the PO may have replaced the MAP sensor.
Any help is greatly appreciated.
Now my problem.
