2003 Rubicon
TL;DR
[rounded a brake line fitting and it seems the old is bigger than 3/16.
can I still use 3/16 or should I try to match the previous size? Help on identifying it? Also any help with fitting identification/verification is appreciated]
So in the process of doing a brake job ( rotors, pads, calipers) I accidentally let the master cylinder run dry while bleeding
That being said I decided I have to bench bleed the master cylinder in order the get the air out and finish the bleed. Well, one of the fittings from the proportion valve to the master cylinder (master cylinder side) became rounded as I was removing it (with a flare wrench).
Looks like it’s time to learn how to flare brake lines, yippee!
doing some research and playing with the fitting size finder at the auto parts store it seems the lines I need are 3/16 and the fittings are 1/2 - 20 and m12 -1.25
(PLEASE CORRECT ME IF IM WRONG
I couldn’t find a suitable replacement for the fitting on the proportion valve side so I figured I’d reuse it since it was still in good shape. That’s when I noticed the problem.
it seems the previous owner did some things to the brake lines and the ones installed are slightly bigger.
I took out my caliper to verify what my eyes saw and sure enough the old lines are bigger and the old fitting doesn’t fit as snug as it did on the old line.
Can anyone verify the size of these lines on a stock wrangler? I read online sometimes these small lines between the cylinder and proportion valve can be larger than the other lines used.
If the previous owner did use a larger line, it seems it’s not 1/4 inch which was my guess. Can anyone chime in on the size?
Can I still use the 3/16 or should I try to keep what was on there?
TL;DR
