Today was dialing in day. Performed an alignment and straightened up the steering wheel. Then started dialing out the slight vibe I had. I've dialed out vibes before, but have been reworking everything suspension, wheels, and steering lately. However, I took a slightly different approach today.
@mrblaine usually says things that make sense, but I read something the other day he said in a thread regarding vibes that.made perfect sense: "...it don't matter what the angle finder say, it only matter what the vibes do." After I thought about this statement with respect to all the get the angle finder advice. How the fuck does the pinion know whether it's 1deg lower than the DS? It doesn't; it does know when it is happy and when it isn't.
So, I left the angle finder on the bench and just started adjusting up and down and let the vibes or lack thereof tell me what angle I need to be at. I was able to get it vibe free up to 75 with a very slight vibe after that through 85. Didn't go any faster than that, cause I don't need to.
Where is the pinion at with respect to the DS? I have know idea and quite frankly don't care. I have in the past used the angle finder relentlessly adjusting by .5 deg all over the fucking place. I spent way more time using the angle finder as I was so focused on 0, .5, 1, 1.5 deg, etc.
I'm not saying you can't dial in your pinion with the angle finder, I'm only saying you don't need a fucking angle finder to do so. Use your head.
Rant and update over.
