Just started my SYE install and broke two of the three bolts in the balancer. I even soaked all of it in PB Blaster well before starting it. Off to get an easy-out kit and some grade 8 bolts.
Yikes. This is something I plan to do in the next two weeks. Any tips on the SYE install overall?
Not enough room to put a nut on them or I would have tried that first.got a welder? cut off a couple bolt heads and drill those as big as you can 1 size smaller than that stud, so you can tack them onto those stud tops.
maybe give each 1 a ping on the end with a punch to try and shock it. then the heat from the tacks could just get it loose maybe? without much heat transfer to anything else.
Run a tap through any time you do something like this. Some vehicles pull brake drums off this way. And there are a few other places this set-up is used. Be sure the tap can turn easily through the threads. Use a better spray lube like Liquid Wrench. Then only use a hardened bolt in them to prevent them twisting off like happened here.
