Ok, so I was poking around the rancho website, they are now using what they call their D2 busing, is it just a Girro Joint, metal cloak, or a DDB? if so it maybe an option for some...who want this style of joint...
I saw the Rancho offering a few months ago, but for me the Clayton Giiro was new. From what I can tell, I believe the Rancho D2, Clayton Giiro, and the Synergy DDB are all the same thing. Old man Emu also offers a similar bushing in their JK arms and Mopar uses a dual durometer bushing in their 2" lift for the JL. I do not know if they are made by the same manufacturer, or if they are all just using a similar concept of dual durometer bushings. This is different than the Metal Cloak bushings.
Metal Cloak bushings use only a single durometer of 'rubber' for isolation. (Although only 1 of the synergy's dual durometers is used for isolation too.) Metal Cloak is kind of like a Clevite bushing that has simply detached from the outside shell of the housing so it can spin freely in the housing. The dual durometer bushings are similar, but instead of spinning inside the housing, they are pressed firmly into the housing and spin around the bolt sleeve.
The MetalCloak requires a layer of grease to be applied to the outside of the bushing. The DDB on the other hand uses a layer of Teflon around the sleeve so that it is maintenance free.
The Metal Cloak can be taken apart to be serviced, re-greased and rebuilt. It is similar to the JJ in this regard. The DDB is not rebuildable, but requires a new bushing to be pressed in if service is required. It is similar to Clevite in this regard.
So they are similar and yet they are different. To my eyes, it seems like the Metal Cloak engineers looked at the JJ and tried to make it softer and more maintenance free. The DDB engineers appear to have started with the Clevite bushing and tried to make it flex more and improved longevity. So coming from two different directions they both ended up somewhere between a JJ and a Clevite bushing.
As you pointed out, we are starting to see a lot of companies moving to a DDB type of bushing. I suspect they are all made by the same manufacturer or at least under license by the same patent holder. They all look very similar. The MC Duroflex is unique to MetalCloak.
I expect that within 5 years you won't see Clevite used at all in aftermarket arms. Everyone will be using a DDB type of bushing. In 10 years from now when Jeep releases the next Wrangler it will likely have a DDB type of bushing as well if they prove to hold up as advertised.
