Check the chain, it takes two minutes, then you can move on to finding the problem. Put wrench on the crankshaft and turn it back and forth, if the chain is worn enough you will hear and feel the slack before it starts moving the cam. Mine was toast and I did not get a code. It did make noise and caused a rough idle.
