My Jeep doesn't start
Alan12
New Jersey
I am sure it’s not the battery... I am new on this and it’s the first time that this happens on this jeep.. I have a 2005 Jeep Wrangler SE 6 speed Manual transmission
Could be the shaft behind the lock cylinder, you can pull the lock cylinder out with the release on the bottom of the column and see if the shaft behind the lock cylinder is broken
Do you hear any relays clicking? Any odd spark snapping sounds? Do all the dash lights com on whith the key? Is it turning over at all? Turning over slow? I've found that the ground wires cause a lot of issues because people tend to keep the hot side wires cleaned up but ignore the ground wires. More details on what is actually happening can help here.
