My 4.0 auto 98 wrangler runs at the desired 210° most of the year, but when the outdoor temperature approaches 100° it bumps up to 213°. The radiator was flushed about 2 years ago. Please advise. Thanks.
Just the gauge.How are you monitoring those temps? The sender and the gauge are not that precise.
That's what I did and went from an OH condition sitting in a parking lot (@102 OAT) to solid 210 on the gage. Since the radiator was out, I did replace the pump and all hoses as well.IF you flushed your radiator two years ago... it may be time to have it chemically cleaned/flushed and look at replacing the thermostat.
Verify the radiator fins are not partially plugged.
I'm interested in this. My 97 Sahara automatic runs at 210 but goes higher on a hot day when idling in traffic. Will overheat & check gauges light comes on if I run the AC while idling as well.
The temperature gauge uses the coolant temperature sensor mounted next to the radiator hose connected to the engine head at the front of the engine.Are there separate sensors for the gauge and ECU? I've seen documentation showing one in the side of the block and it also appears that there is one near the thermostat.
I get somewhat of the same issue. I checked today after it ran for a solid 30 minutes. I was able to spin it pretty freely, not a whole ton of resistance. But if I gave it a push to spin on its own, it’d only make about anywhere between an 1/8 - 1/4 of a full turn. It’s never been replaced as far as I could tell, or my water pump. Mopar radiator last summer, head gasket this past winter.That little amount over 210, estimating 213, in hot conditions should be considered normal. I wouldn't worry about it. Make sure though that your fan clutch is operating, that's what turns the fan on when the engine is hot. With the engine hot, check that the fan is very stiff and difficult to rotate by hand. If the fan spins freely when the engine is hot that means the engine can't spin it fast enough which can cause the engine to run warmer. If the fan spins freely when the engine's hot, replace the fan clutch.
Good to know, thanks as always! I’ll order one up tonightTime to replace, it shouldn't free-wheel that much when it's hot.
